[GRASS-dev] Export from GRASS to Postgres
suprakash maitra
suprakashmaitra at yahoo.com
Wed Apr 3 05:14:16 PDT 2013
Hi All,
I am trying to export GRASS maps/mapsets to PostgreSQL.At the time of installation of GRASS ,I have configured it with Postgres.
The command used is:
v.out.ogr -c input=fields type=area 'dsn=PG:host=localhost dbname=grass user=grassuser password=grassuser' olayer=fields2postgis layer=1 format=PostgreSQL
The database grass is postgis enabled.
However the format "PostgreSQL" is taken as invalid format.
Without "PostgreSql" format the maps are exported to ESRI_shapefile format.
One thing more, There is no PostgreSql format type in OGR format dropdown list in case of using GUI.
Please help me out.
Thanks in advance.
"If you don't know where you are going any road will get you there"
Regards
Suprakash
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130403/dc4378d9/attachment.html>
