[GRASS-dev] [GRASS GIS] #1915: v.out.ogr: problem to export certain column(s)
GRASS GIS trac at osgeo.org
Thu Apr 4 02:14:19 PDT 2013
 Reporter:  neteler           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Vector            |     Version:  svn-trunk
 Keywords:  v.out.ogr, wxGUI  |    Platform:  Linux
      Cpu:  All               |
Changes (by neteler):
  * keywords:  v.out.ogr => v.out.ogr, wxGUI
Comment:
 Renaming the column help:
 GRASS 7.0.svn (ll_wgs84):~ > v.db.renamecolumn dep_new_clean
 column=normalization,area_norm
 GRASS 7.0.svn (ll_wgs84):~ > v.out.ogr dep_new_clean dsn=dep_new_clean.shp
 type=area
 Warning 1: Field PROVDEP of width 1000 truncated to 255.
 Warning 1: Field MIN_NOMDEP of width 1000 truncated to 255.
 Warning 1: Field JURISDICC of width 1000 truncated to 255.
 Warning 1: Field MIN_DEPTO of width 1000 truncated to 255.
 Warning 1: Field MIN_PROV of width 1000 truncated to 255.
 Warning 1: Field PROVINCIA of width 1000 truncated to 255.
 Exporting 702 areas (may take some time)...
  100%
 v.out.ogr complete. 702 features written to <dep_new_clean>
 (ESRI_Shapefile).
 Hence this is a bug (non-feature) in either v.db.addcolumn or
 the wxGUI Attribute manager.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1915#comment:1>
