[GRASS-dev] [GRASS GIS] #1915: v.out.ogr: problem to export certain column(s)
GRASS GIS trac at osgeo.org
Thu Apr 4 02:25:04 PDT 2013
 Reporter:  neteler           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Vector            |     Version:  svn-trunk
 Keywords:  v.out.ogr, wxGUI  |    Platform:  Linux
      Cpu:  All               |
Comment(by mmetz):
 Replying to [comment:1 neteler]:
 > Renaming the column help:
 > Hence this is a bug (non-feature) in either v.db.addcolumn or
 > the wxGUI Attribute manager.
 No, it is a limitation of dbf as used by the OGR ESRI_Shapefile driver.
 The column name 'normalization' is too long for dbf.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1915#comment:2>
