[GRASS-dev] verbose in grass.array .write() function
Glynn Clements
glynn at gclements.plus.com
Sat Apr 6 01:32:34 PDT 2013
Johannes Radinger wrote:
> in GRASS 6.5 the python array.write() function in
> http://svn.osgeo.org/grass/grass/branches/develbranch_6/lib/python/array.py
> has set verbose=TRUE. Is there any reason for that?
It was probably added during development and not reverted.
> It seems when using the .write() function in a personal
> script the verbose-level is not parsed to that underlying function. So
> even when in the script the quiet-flag is set, an output (progress,
> percentage) is still printed. So maybe some lines like in
> http://svn.osgeo.org/grass/grass/branches/develbranch_6/lib/python/raster.py
> could be added for this function as well:
> if quiet:
> env['GRASS_VERBOSE'] = '0'
> if verbose:
> env['GRASS_VERBOSE'] = '3'
> if overwrite:
> env['GRASS_OVERWRITE'] = '1'
That's not necessary; it should either pass quiet=True or pass neither
quiet= nor verbose=, and allow the script's verbosity setting to be
inherited.
