[GRASS-dev] r.fillnulls failure (grass7 )
Markus Neteler neteler at osgeo.org
Sun Apr 7 14:20:56 PDT 2013
On Sun, Apr 7, 2013 at 11:00 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> Try to remove zcol = 'value' from the call to v.surf.rst in the
> r.fillnulls script. The vector created by r.fillnulls with r.to.vect
> is 3D, so no z column is needed (or present).
Tested, this solves the problem. I guess it is an artifact of the -z usage
in the GRASS 6 version or the r.to.vect usage.
markusN
