[GRASS-dev] r.fillnulls failure (grass7 )
epi massimodisasha at gmail.com
Tue Apr 9 17:20:25 PDT 2013
thanks this fixed my problem! :)
Il giorno 07/apr/2013, alle ore 17:20, Markus Neteler <neteler at osgeo.org> ha scritto:
> On Sun, Apr 7, 2013 at 11:00 PM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
>> Try to remove zcol = 'value' from the call to v.surf.rst in the
>> r.fillnulls script. The vector created by r.fillnulls with r.to.vect
>> is 3D, so no z column is needed (or present).
> Tested, this solves the problem. I guess it is an artifact of the -z usage
> in the GRASS 6 version or the r.to.vect usage.
> markusN
