[GRASS-dev] verbose in grass.array .write() function
Mon Apr 8 02:34:04 PDT 2013
Johannes Radinger wrote:
> So actually verbose=True should then be removed from the function
> so that it behaves like other GRASS modules and the verbosity level
> setting is inherited from the script in which .write() is used?
I think so.
