[GRASS-dev] Export from GRASS to Postgres
suprakash maitra suprakashmaitra at yahoo.com
Mon Apr 8 05:51:22 PDT 2013
v.in.ogr -f
 ESRI Shapefile (rw): ESRI Shapefile
 MapInfo File (rw): MapInfo File
 UK .NTF (ro): UK .NTF
 SDTS (ro): SDTS
 TIGER (rw): TIGER
 S57 (rw): S57
 DGN (rw): DGN
 VRT (ro): VRT
 REC (ro): REC
 Memory (rw): Memory
 BNA (rw): BNA
 CSV (rw): CSV
 GML (rw): GML
 GPX (rw): GPX
 KML (rw): KML
 GeoJSON (rw): GeoJSON
 GMT (rw): GMT
 SQLite (rw): SQLite
 PCIDSK (rw): PCIDSK
 XPlane (ro): XPlane
 AVCBin (ro): AVCBin
 AVCE00 (ro): AVCE00
 DXF (rw): DXF
 Geoconcept (rw): Geoconcept
 GeoRSS (rw): GeoRSS
 GPSTrackMaker (rw): GPSTrackMaker
 VFK (ro): VFK
 PGDump (rw): PGDump
 GPSBabel (rw): GPSBabel
 SUA (ro): SUA
 OpenAir (ro): OpenAir
 PDS (ro): PDS
 WFS (ro): WFS
 HTF (ro): HTF
 AeronavFAA (ro): AeronavFAA
Available OGR Drivers:
(Mon Apr  8 18:17:56 2013) Command finished (0 sec)
[user at lab35 local]$ ogrinfo --formats
Supported Formats:
  -> "ESRI Shapefile" (read/write)
  -> "MapInfo File" (read/write)
  -> "UK .NTF" (readonly)
  -> "SDTS" (readonly)
  -> "TIGER" (read/write)
  -> "S57" (read/write)
  -> "DGN" (read/write)
  -> "VRT" (readonly)
  -> "REC" (readonly)
  -> "Memory" (read/write)
  -> "BNA" (read/write)
  -> "CSV" (read/write)
  -> "GML" (read/write)
  -> "GPX" (read/write)
  -> "KML" (read/write)
  -> "GeoJSON" (read/write)
  -> "GMT" (read/write)
  -> "SQLite" (read/write)
  -> "PostgreSQL" (read/write)
  -> "PCIDSK" (read/write)
  -> "XPlane" (readonly)
  -> "AVCBin" (readonly)
  -> "AVCE00" (readonly)
  -> "DXF" (read/write)
  -> "Geoconcept" (read/write)
  -> "GeoRSS" (read/write)
  -> "GPSTrackMaker" (read/write)
  -> "VFK" (readonly)
  -> "PGDump" (read/write)
  -> "GPSBabel" (read/write)
  -> "SUA" (readonly)
  -> "OpenAir" (readonly)
  -> "PDS" (readonly)
  -> "WFS" (readonly)
  -> "HTF" (readonly)
  -> "AeronavFAA" (readonly)
    "If you don't know where you are going any road will get you there"
Regards
Suprakash
 From: suprakash maitra <suprakashmaitra at yahoo.com>
To: "grass-dev at lists.osgeo.org" <grass-dev at lists.osgeo.org>
Sent: Monday, April 8, 2013 4:00 PM
Subject: Re: Export from GRASS to Postgres
Hi
I am using Fedora15,GRASS-6.4.2,gdal-1.8.1,postgresql-9.1.I have compiled gdal with postgresql support and GRASS with gdal and postgreSQL support ,even then while exporting map/mapset to postgreSQL the format PostgreSQL is not supported.
Plz help me out.
Regards
Suprakash
Sent: Wednesday, April 3, 2013 5:44 PM
Subject: Export from GRASS to Postgres
Hi All,
I am trying to export GRASS maps/mapsets to PostgreSQL.At the time of installation of GRASS ,I have configured it with Postgres.
The command used is:
v.out.ogr -c input=fields type=area 'dsn=PG:host=localhost dbname=grass user=grassuser password=grassuser' olayer=fields2postgis layer=1 format=PostgreSQL
The database grass is postgis enabled.
However the format "PostgreSQL" is taken as invalid format.
Without "PostgreSql" format the maps are exported to ESRI_shapefile format.
One thing more, There is no PostgreSql format type in OGR format dropdown list in case of using GUI.
Please help me out.
Thanks in advance.
Regards
Suprakash
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130408/138f2b15/attachment.html>
