[GRASS-dev] Export from GRASS to Postgres
Martin Landa landa.martin at gmail.com
Mon Apr 8 06:04:07 PDT 2013
2013/4/8 suprakash maitra <suprakashmaitra at yahoo.com>:
>   -> "PostgreSQL" (read/write)
then GRASS is probably using different GDAL library which is built
without PostgreSQL. Check if there are more GDAL installations on your
machine. See the previous answer.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
