[GRASS-dev] Export from GRASS to Postgres
Martin Landa landa.martin at gmail.com
Mon Apr 8 06:07:28 PDT 2013
2013/4/8 Martin Landa <landa.martin at gmail.com>:
> 2013/4/8 suprakash maitra <suprakashmaitra at yahoo.com>:
>>   -> "PostgreSQL" (read/write)
> then GRASS is probably using different GDAL library which is built
> without PostgreSQL. Check if there are more GDAL installations on your
> machine. See the previous answer.
in other words, what says?
ogrinfo --version
gdal-config --libs
g.version -e (in GRASS 7)
or
g.version -b (in GRASS 6)
Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
