[GRASS-dev] [GRASS GIS] #1832: Python scripts are with mixed tabs and spaces
GRASS GIS trac at osgeo.org
Wed Apr 10 05:27:33 PDT 2013
 Reporter:  klo          |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Python       |     Version:  unspecified
 Keywords:  indent       |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [comment:8 hamish]:
 > Replying to [ticket:1832 klo]:
 > > Mixing tabs and spaces is not good idea:
 http://www.python.org/dev/peps/pep-0008/#tabs-or-spaces
 > annoyingly, it asserts it is so but does not explain why. is it just
 that lots of people submit code after editing with braindead text editors,
 or is it something inherent in the python language which makes it so...?
 Python uses indentation to determine block boundaries, so indentation
 matters.
 Some text editors treat tab stops as configurable, but there's no way for
 the Python interpreter to know how the editor is configured, so it assumes
 that tab stops are every 8 columns. If you use an editor which is set to
 use e.g. 4-column tabs, then a line indented by 4 spaces and a line
 indented by a tab will appear to be at the same indentation level, but
 Python will treat the latter as indented more than the former.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1832#comment:10>
