[GRASS-dev] [GRASS GIS] #1428: WinGRASS + how to deliver Microsoft Visual C++ Redistributable Package (vcredist)?
trac at osgeo.org
Mon Apr 15 20:18:55 PDT 2013
(vcredist)?
Reporter: dhastings | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: Installation | Version: 6.4.3 RCs
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hamish):
Hamish:
> Our next step seems to be some quality time spent exploring
> with Dependency Walker..
ok, done a bit of that, it seems that we need the full set of
redistributables.
A small sample from dragging the dlls into depends.exe:
libgrass_gis6.4.3snv.dll req's msvcrt.dll
libgrass_gis6.4.3snv.dll req's msvcp60.dll
zlib1.dll req's msvcrt.dll
libpq.dll req's msvcrt.dll
libpq.dll req's msvcp60.dll
libpq.dll req's msvcr71.dll
libpq.dll req's msvcr80.dll
libxml2.dll req's msvcp60.dll
zlib_osgeo.dll req's msvcr71.dll
proj.dll req's msvcr71.dll
tk85.dll req's msvcr90.dll
geotiff.dll req's msvcp90.dll
geos_c.dll req's msvcp100.dll
geos_c.dll req's msvcr100.dll
gdal19.dll req's them all
as does gdal18.dll and gdal15.dll
(what depends on gdal18.dll and gdal15.dll? can we leave them out saving
10mb?)
So even if Ben's osgeo4w toolchain were all compiled without MS Visual
Studio, we'd still need the redistributables for PgSQL & co. which we
aren't building ourselves.
msvcp60.dll and msvcrt.dll are in my C:\Windows\system32\ already, maybe
they ship with Windows by default? (or maybe I installed them, dunno at
this point)
many things would like to find MSJAVA.DLL, but it isn't there.
But that's not a problem because it's called by MSHTML.DLL which can
deal with it being missing. (see Dependency Walker FAQ)
As Helmut notes in the GRASS-Installer.nsi.tmpl text about the MSVC++
redist. pkg both python.exe and GDAL19.dll require MSVCP100.dll, this is
the error I get on wxGUI startup on an old XP install:
python.exe - Unable To Locate Component
This application has failed to start because MSVCP100.dll was not found.
Re-installing the application may fix this problem.
[Ok]
g.region.exe, g.proj.exe, fail since they both depend on libgrass_gproj,
which wants gdal19.dll, which wants msvcp100.dll.. that means the tcl/tk
GUI also fails with:
g.proj or projection error: child killed: unknown signal
Error setting region (Problem with g.region?): child killed: unknown
signal
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1428#comment:49>
