[GRASS-dev] [GRASS GIS] #731: Warning message after removing layer confusing (was: Warming message after removing layer confusing)
GRASS GIS trac at osgeo.org
Wed Apr 17 00:28:51 PDT 2013
  Reporter:  pvanbosgeo  |       Owner:  grass-dev@…
      Type:  defect      |      Status:  closed
  Priority:  normal      |   Milestone:  6.4.0
 Component:  Default     |     Version:  svn-develbranch6
Resolution:  fixed       |    Keywords:  g.remove, delete, message
  Platform:  Linux       |         Cpu:  x86-64
Changes (by hamish):
  * keywords:  remove, delete, message => g.remove, delete, message
  * status:  new => closed
  * resolution:  => fixed
Comment:
 current behaviour in 6.4.3svn:
 GRASS> g.copy geology,geology
 Copy raster <geology at PERMANENT> to current mapset as <geology>
 GRASS> g.remove geology
 Removing raster <geology>
 WARNING: 'cell/geology' was found in more mapsets (also found in
          <PERMANENT>)
 WARNING: Using <geology at user1>
 seems like it got fixed.
 note only maps from the current mapset can be written to (or deleted).
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/731#comment:1>
