[GRASS-dev] [GRASS GIS] #891: add a command g.move
GRASS GIS trac at osgeo.org
Wed Apr 17 00:42:52 PDT 2013
  Reporter:  timmie       |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  6.5.0
 Component:  Default      |     Version:  unspecified
Resolution:  wontfix      |    Keywords:  g.move
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by hamish):
  * keywords:  => g.move
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 It's not really about other users on the system (you can't write to
 directories you don't own either, and grass enforces that for mapset
 access even if there is filesystem group write permissions set), it's more
 about safe concurrent use. If you had two GRASS sessions running in
 parallel, it wouldn't be very nice if the other one suddenly overwrote a
 map in the one you were working in. The same is true for why starting two
 GRASSes running in the same mapset is disallowed (also in that case a
 change by g.region by the twin session could be damaging).
 so it's about keeping the paperwork in order and goes pull, not push.
 see also the r.pack, r.unpack modules if you need to transfer maps between
 different systems/locations, and g.laptop.sh from Addons:
  http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#g.laptop.sh
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/891#comment:4>
