[GRASS-dev] [GRASS-SVN] r55864 - in grass/branches/releasebranch_6_4: display/d.where general/g.mapset imagery/i.topo.corr lib/init raster/r.in.gdal raster/r.region scripts/v.db.join scripts/v.db.update vector vector/v.what
Markus Neteler neteler at osgeo.org
Wed Apr 17 23:07:09 PDT 2013
On Thu, Apr 18, 2013 at 7:56 AM,  <svn_grass at osgeo.org> wrote:
> Author: hamish
> Date: 2013-04-17 22:56:53 -0700 (Wed, 17 Apr 2013)
> New Revision: 55864
> Modified:
>    grass/branches/releasebranch_6_4/scripts/v.db.join/v.db.join
>    grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
> Log:
> clean up language (#1591, partial merge of r55862 from trunk)
> Modified: grass/branches/releasebranch_6_4/scripts/v.db.join/v.db.join
> --- grass/branches/releasebranch_6_4/scripts/v.db.join/v.db.join        2013-04-18 05:50:21 UTC (rev 55863)
> +++ grass/branches/releasebranch_6_4/scripts/v.db.join/v.db.join        2013-04-18 05:56:53 UTC (rev 55864)
> @@ -14,7 +14,7 @@
>  #%Module
> -#% description: Allows to join a table to a vector map table.
> +#% description: Joins a database table to a vector map table.
--> please don't break the translations if not really needed!
> Modified: grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
> --- grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update    2013-04-18 05:50:21 UTC (rev 55863)
> +++ grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update    2013-04-18 05:56:53 UTC (rev 55864)
> @@ -15,7 +15,7 @@
>  #%Module
> -#%  description: Allows to update a column in the attribute table connected to a vector map.
> +#%  description: Updates a column in the attribute table connected to a vector map.
--> same here. Now for up to 16 languages the strings must be remerged into
the .po files, translated and updated in SVN...
Markus
