[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
trac at osgeo.org
Thu Apr 18 04:08:12 PDT 2013
Reporter: antonioall | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Keywords: v.in.lines, g.tempfile | Platform: MSWindows 7
Cpu: x86-64 |
Changes (by hamish):
* keywords: v.in.lines => v.in.lines, g.tempfile
* priority: normal => critical
Comment:
ok, I can reproduce the error on XP 32bit with the latest nightly 6.5
wingrass build, if I run it from the wxGUI File->Import vector data menu.
you wrote:
C:/GRASS GIS 6.4.3svn/scripts/v.in.lines: line 108:
/otherMyPath/PERMANENT/.tmp/4520.0: No such file or
directory
head: cannot open `/otherMyPath/PERMANENT/.tmp/4520.0' for reading: No
such file or directory
the problem seems to be with g.tempfile, it's leaving the C: off the temp
file name.
It creates the tempfile ok, but I think in the script it needs to start
with "/c/" ?
.. right, changing v.in.lines to:
TEMPFILE=/c"`g.tempfile pid=$$`"
allows v.in.lines process the temp file. (but then v.in.mapgen chokes on
its tempfile).
`g.tempfile pid=123` run from the wxGUI Command Console shows the same
behaviour: the tempfile name in the output canvas is "/Documents and
Settings/Username/My Documents/GIS DataBase/spearfish60/user1/.tmp/123.0",
without /c or C: to start it.
(also not very good if you data is on D: but grass is installed to
C:\Program Files)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:7>
