[GRASS-dev] [GRASS GIS] #1936: wxGUI command console: "Protocol" isn't really the right word & cleanup
trac at osgeo.org
Thu Apr 18 04:20:08 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: unspecified
Keywords: command console | Platform: Unspecified
Cpu: Unspecified |
in the wxGUI command console tab there's a "Protocol" button.
I don't think the word really fits, or at least it's an awkward use of it.
Perhaps "Journal", "Command Log", or "History" would be better? "script"
might also fit, but I'd worry it would get confused with running a script.
(my 2c vote would go to "Journal", and if we're going to change it we
should try before the release)
thanks,
Hamish
ps- also in the command console tab, "Click here to show search module
engine >>" .. shouldn't that be on the Search module tab instead of taking
valuable screen real estate away from the output canvas?
pps- still in the command console tab: there's an empty bar above the
Clear/Save button row. When it's not being used for % done, could it do
double duty and go below the buttons with "Manually enter commands below:"
or some text? To a new user, at the start that tab just has two big white
boxes, it's not clear what either of them are and that it is possible to
type into the lower pane and have it do something.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1936>
