[GRASS-dev] [GRASS GIS] #640: setup.py may use different Python than configured for GRASS
trac at osgeo.org
Thu Apr 18 12:15:46 PDT 2013
Reporter: kyngchaos | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Compiling | Version: 6.4.0 RCs
Keywords: python | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:6 hamish]:
> ok, so the question becomes what uses Python.make,
Python.make is used by gui/wxpython, gui/scripts, scripts/r.in.wms, and
various subdirectories of lib/python.
GRASS 7 doesn't have any C or C++ code which links against the Python
library. The preferred way of integrating C and Python code is to use
ctypes to access C functions from Python.
The PYTHON make variable exists to simplify the case where the default
"python" command isn't suitable for GRASS (e.g. because it's Python 3.x,
or it doesn't have the numpy, wxPython, etc packages). In such cases, it
can be overridden on the command line, e.g. "make
PYTHON=/usr/local/bin/python2".
Ticket URL: <https://trac.osgeo.org/grass/ticket/640#comment:8>
