[GRASS-dev] [GRASS GIS] #854: g.extension does not work on a Mac (probably not on Windows either
GRASS GIS trac at osgeo.org
Thu Apr 18 14:41:10 PDT 2013
 Reporter:  cmbarton             |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  normal               |   Milestone:  6.4.3
Component:  Addons               |     Version:  svn-releasebranch64
 Keywords:  g.extension, addons  |    Platform:  All
      Cpu:  All                  |
Comment(by cmbarton):
 Markus asked me to check with r.fuzzy. It still doesn't work but gives a
 different error:
 g.extension extension=r.fuzzy svnurl=http://svn.osgeo.org/grass/grass-
 addons/grass7
 Fetching <r.fuzzy> from GRASS-Addons SVN (be patient)...
 Compiling...
 main.c: In function 'main':
 main.c:149: warning: format not a string literal and no
 format arguments
 main.c:152: warning: format not a string literal and no
 format arguments
 format arguments
 format arguments
 main.c:50: warning: assignment from incompatible pointer
 type
 type
 main.c:62: warning: assignment from incompatible pointer
 type
 format arguments
 main.c:153: warning: format not a string literal and no
 format arguments
 main.c:155: warning: format not a string literal and no
 format arguments
 type
 format arguments
 format arguments
 format arguments
 map_parser.c: In function 'parse_map_file':
 map_parser.c:91: warning: format not a string literal and no
 format arguments
 format arguments
 rule_parser.c: In function 'parse_rules':
 rule_parser.c:132: warning: format not a string literal and
 no format arguments
 no format arguments
 Installing...
 make: *** No rule to make target `install'.  Stop.
 WARNING: Installation failed, sorry. Please check above error messages.
Ticket URL: <https://trac.osgeo.org/grass/ticket/854#comment:24>
