[GRASS-dev] [GRASS GIS] #1945: wingrass: Command Line can't find grass.python libs
GRASS GIS trac at osgeo.org
Tue Apr 23 06:20:13 PDT 2013
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  6.4.3
Component:  Python    |     Version:  svn-develbranch6
 Keywords:  wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32    |
Comment(by hamish):
 Replying to [comment:2 hamish]:
 > ... %PYTHONHOME% is set but %PYTHONPATH% is empty.
 try for a fix for PYTHONPATH in devbr6 r55955. please test.
 > Slightly unrelated, but I'd also note that running 'python' from the
 GRASS+MSYS
 > prompt just freezes the window, you need to click the window's "X" and
 abandon
 > the session. I notice that grass65svn.sh contains several path variables
 (incl.
 > $PYTHONHOME) which are using C:\... paths instead of g.dirsep'd /c/...
 versions.
 if it helps, small path fixer function added to init.sh, copied here:
 dos2unix_path()
    echo "$1" | sed -e 's|^\([A-Za-z]\):|/\1|' -e 's|\\|/|g'
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1945#comment:3>
