[GRASS-dev] [GRASS GIS] #1945: wingrass: Command Line can't find grass.python libs
GRASS GIS trac at osgeo.org
Tue Apr 23 17:44:56 PDT 2013
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  6.4.3
Component:  Python    |     Version:  svn-develbranch6
 Keywords:  wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32    |
Comment(by hamish):
 ok, seems fixed in devbr6 with r55960. a couple outstanding issues-
  - init.bat adds %GISBASE%/etc/wpython to %PYTHONPATH%, but nothing else
 seems to, and a g.gui wxGUI started from the cmd.exe Command Line seems to
 work fine with wxNviz, wxVdigit, etc.. Going to the python console tab in
 the layer manager and doing
 import os
 print os.getenv('PYTHONPATH')
 shows that the GUI itself isn't adding the wxpython dir to $PYTHONPATH (at
 least the one that python console sees; not sure if it is shared with the
 gui process). so is having etc/wxpython in PYTHONPATH not needed at all?
  - even with 'g.gisenv set="GRASS_GUI=tcltk"' the module GUIs started from
 the cmd.exe get wxpython GUIs. When running from the msys terminal those
 get tcltk ones. not a big problem, but why?
    - ok, I see now, there's an enviro var %GRASS_GUI%=text also set, and
 parser.c looks for an enviro var setting before the g.gisenv GRASS_GUI
 setting. "text" is ignored, so the fallback is to wxpython. Perhaps
 GRASS_GUI=text should call the old text "GRASS_UI_TERM" based parser
 instead?
    - after setting the %GRASS_GUI% enviro var to tcltk, I get an error in
 the cmd.exe window:
 'C:\Program' is not recognized as an internal or external command,
 operable program or batch file.
 perhaps this line in parser.c's G_gui_tcltk() needs extra quoting around
 $env(GISBASE)?
 fprintf(fp, "source $env(GISBASE)/etc/gui.tcl\n");
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1945#comment:4>
