[GRASS-dev] [GRASS GIS] #1949: module gui doesn't release if no map display window
GRASS GIS trac at osgeo.org
Wed Apr 24 20:33:05 PDT 2013
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  wxGUI        |     Version:  svn-develbranch6
 Keywords:  module guis  |    Platform:  All
      Cpu:  All          |
 (wingrass 6.5svn nightly build r55955)
 I had closed the Map Display window since I was just testing data import
 and looking at processing reports.
 When running a module in wxGUI (desktop icon startup) the control buttons
 that are greyed out during the run never come back.
 test module: g.region from the menu, select -p flag from the Print tab and
 [Run]
 traceback error printed to the output tab:
   File "C:\Program Files\GRASS GIS
 6.5.svn\etc\wxpython\gui_core\goutput.py", line 867, in
 OnCmdDone
 event.onDone(cmd = event.cmd, returncode = event.returncode)
 6.5.svn\etc\wxpython\gui_core\forms.py", line 595, in OnDone
 display = self.parent.GetLayerTree().GetMapDisplay()
 AttributeError
 'NoneType' object has no attribute 'GetMapDisplay'
 tested and the same happens in Linux.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1949>
