[GRASS-dev] [GRASS GIS] #1949: module gui doesn't release if no map display window
GRASS GIS trac at osgeo.org
Wed Apr 24 23:31:26 PDT 2013
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  wxGUI        |     Version:  svn-develbranch6
 Keywords:  module guis  |    Platform:  All
      Cpu:  All          |
Comment(by annakrat):
 Replying to [ticket:1949 hamish]:
 > When running a module in wxGUI (desktop icon startup) the control
 buttons that are greyed out during the run never come back.
 What exactly do you mean with control buttons?
 > test module: g.region from the menu, select -p flag from the Print tab
 and [Run]
 > traceback error printed to the output tab:
 > Traceback (most recent call last):
 > display = self.parent.GetLayerTree().GetMapDisplay()
 > AttributeError
 > 'NoneType' object has no attribute 'GetMapDisplay'
 should be fixed in r55989.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1949#comment:1>
