[GRASS-dev] [GRASS GIS] #1662: Caching bug in 3D raster library with large data
Sören Gebbert soerengebbert at googlemail.com
Mon Aug 26 11:54:44 PDT 2013
Sorry for replying directly to the list, but the grass trac server
seems to be down or very, very busy.
Replying to [comment:4 annakrat]:
> I tested it on 32Bit Ubuntu and I get a segmentation fault after 100% is finished. Should I test something else?
Many thanks for the test.
Can you please run the test in the gnu debugger (gdb) again, so that i
can get an idea of what the reason for the segfault is? You can
create a backtrace after the segfault occurred with "bt" in the gdb
session.
Example:
gdb test.g3d.lib
r unit=large
..... segfault
bt
Can you then please provide the output of the backtrace command "bt"?
2013/8/26 GRASS GIS <trac at osgeo.org>:
>  Reporter:  huhabla                  |       Owner:  grass-dev@…
>      Type:  defect                   |      Status:  new
>  Priority:  critical                 |   Milestone:  7.0.0
> Component:  Raster3D                 |     Version:  svn-trunk
>  Keywords:  3D raster, tiles, cache  |    Platform:  Linux
>       Cpu:  x86-32                   |
> Comment(by annakrat):
> Ticket URL: <http://trac.osgeo.org/grass/ticket/1662#comment:4>
> GRASS GIS <http://grass.osgeo.org>
