[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
trac at osgeo.org
Mon Aug 26 14:14:09 PDT 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: g.region, r.colors, r.mask | Platform: Linux
Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1778 pvanbosgeo]:
> Normally when you type a command, e.g., g.region, without parameters, a
new window for that command opens.
> This does not seem to work for a few commands at the moment. Three ones
that seem to be affected are g.region, g.rename and g.copy.
This is normal. If a command doesn't have any required options, executing
the command without parameters will not open a parameter dialog. You can
force a parameter dialog to be displayed using the --ui switch.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1778#comment:6>
