[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
GRASS GIS trac at osgeo.org
Tue Aug 27 02:58:31 PDT 2013
 Reporter:  pvanbosgeo                  |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  critical                    |   Milestone:  7.0.0
Component:  Default                     |     Version:  svn-trunk
 Keywords:  g.region, r.colors, r.mask  |    Platform:  Linux
      Cpu:  x86-64                      |
Comment(by neteler):
 Replying to [comment:8 martinl]:
 > Replying to [comment:6 glynn]:
 > > This is normal. If a command doesn't have any required options,
 executing the command without parameters will not open a parameter dialog.
 You can force a parameter dialog to be displayed using the --ui switch.
 > I would call it rather "current behaviour". It's probably confusing to
 the user. Is there any reason why the dialog is not open in this case?
 For example, from d.erase (on CMD line) you expect that the screen be
 erased, not that
 you have to do extra GUI clicking. Or do you refer to g.region?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1778#comment:9>
