[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
trac at osgeo.org
Tue Aug 27 03:06:31 PDT 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: g.region, r.colors, r.mask | Platform: Linux
Cpu: x86-64 |
Comment(by martinl):
Replying to [comment:9 neteler]:
> Replying to [comment:8 martinl]:
> > Replying to [comment:6 glynn]:
> > > This is normal. If a command doesn't have any required options,
executing the command without parameters will not open a parameter dialog.
You can force a parameter dialog to be displayed using the --ui switch.
> > I would call it rather "current behaviour". It's probably confusing to
the user. Is there any reason why the dialog is not open in this case?
> For example, from d.erase (on CMD line) you expect that the screen be
erased, not that
> you have to do extra GUI clicking. Or do you refer to g.region?
yes, I am referring to `g.region`. There are probably more modules without
required parameters which have no expected effect as eg. `d.erase`.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1778#comment:10>
