[GRASS-dev] [GRASS GIS] #2061: Export raster error
GRASS GIS trac at osgeo.org
Tue Aug 27 06:32:04 PDT 2013
 Reporter:  romanigis       |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  6.4.3
Component:  Raster          |     Version:  6.4.3 RCs
 Keywords:  raster, export  |    Platform:  MSWindows 7
      Cpu:  x86-32          |
 Hi.
 I am trying to export a raster surface generated from points.
 There was no problem reading my file (v.in.ascii) in a text format
 consisting of XYZ columns and setting a region. There was no problem
 creating a surface from these points (v.surf.rst). The surface is
 displayed in Map Display and I can navigate in it. The problem occurs when
 I want to export this surface either as a GeoTiff or ESRI GRID File -
 r.out.arc/r.out.tiff answers with "ERROR: Unable to open file
 <my_surface>.
 Any ideas?
 Thanks for help
 Roman Højsager Varinsky
Ticket URL: <http://trac.osgeo.org/grass/ticket/2061>
