[GRASS-dev] [GRASS GIS] #1480: v.outlier - distinguish positive and negative outlier filtering from lidar point clouds
trac at osgeo.org
Tue Dec 3 05:48:43 PST 2013
point clouds
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: unspecified
Keywords: review | Platform: All
Cpu: All |
Changes (by sbl):
* version: svn-develbranch6 => unspecified
* milestone: 6.4.2 => 7.0.0
Comment:
Recently we had another project where we got insufficient filtered LIDAR
data, where especially returns from lower mountainous vegetation were
classified as "ground return". Filtering only last return was already done
in the classification process (applied by the LIDAR-operator) and
therewith insufficient too.
The multi-scale curvature classification (mcc) procedure developed by
Evans & Hudak 2007 (PDF linked above) however helped filtering out at
least some more vegetation returns.
I created a GRASS 7 AddOn (python script) which applies the mcc procedure.
It is not uploaded to svn yet and some more testing will be necessary in
order to write a useful manual. But I could attach it as a prove of
concept if that is of interest. However, it requires that the
v.outlier.diff is applied.
Therefore I would like to ask if the decision not to change v.outlier
(because of the different concept of the module) could be reconsidered?
The mcc-algorithm was really useful for us at least...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1480#comment:3>
