[GRASS-dev] [GRASS GIS] #1791: gui modeler: cannot load file with r.mapcalc expression containing '&&' operator
trac at osgeo.org
Tue Dec 3 06:22:03 PST 2013
operator
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: modeler r.mapcalc
Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:2 wenzeslaus]:
> Thanks for reminding about this issue. It is actually trivial (at least
I hope that I haven't overlooked something). Should be fixed for trunk in
r58371.
> I tested it but it would be better if you test it, too, XML can be
tricky.
It works here when you create a new model file. One which already contains
'&&' still cannot be loaded (which is logical as your change concerns
writing the file), but I guess that this cannot be easily solved and that
your solution is good enough. Any existing model files still have to be
handled manually, but as soon as you save them again the issue is solved.
I'm closing the bug for now.
Thanks for the quick fix !
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1791#comment:3>
