[GRASS-dev] Removing _STDIO_H ifndefs
Vaclav Petras
wenzeslaus at gmail.com
Thu Dec 5 19:57:17 PST 2013
Hi all,
there are some preprocessor ifndefs which I don't completely understand
but, from what I understand, they should be removed.
There are two contexts where it is used:
#ifndef _STDIO_H
#include <stdio.h>
#endif
which is useless since this check should be done in stdio.h.
The other usage is:
#ifdef _STDIO_H
int do_label(FILE *, int);
#endif
which in case of not defined _STDIO_H will not declare that function and so
it will break the code later in the compilation where this function is used
(depending code is not marked by #ifdef).
It actually breaks with standard C library which does not define _STDIO_H
but something else, e.g. the one which goes with the latest Mac OS X XCode
(at least to my current understanding). I guess there is not reason to to
"ifdef stdio.h" any parts of code now, so we can just remove all these.
Patch attached, once it is approved I will commit it. Compiled so far only
on Ubuntu.
Objections? Explanations?
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131205/eeb782fc/attachment.html>
Index: include/defs/dig_atts.h
--- include/defs/dig_atts.h (revision 58395)
+++ include/defs/dig_atts.h (working copy)
@@ -1,6 +1,4 @@
-#ifndef _STDIO_H
#include <stdio.h>
-#endif
#define WRITE_ATT_FORMAT "%c %12.2lf %12.2lf %8d"
Index: include/bitmap.h
--- include/bitmap.h (revision 58395)
+++ include/bitmap.h (working copy)
@@ -33,9 +33,7 @@
struct BMlink *next;
-#ifndef _STDIO_H
#include <stdio.h>
-#endif
#include <grass/defs/bitmap.h>
Index: include/vect/dig_structs.h
--- include/vect/dig_structs.h (revision 58395)
+++ include/vect/dig_structs.h (working copy)
@@ -13,10 +13,7 @@
#ifndef DIG___STRUCTS___
#define DIG___STRUCTS___
-/* this file depends on <stdio.h> */
-#ifndef _STDIO_H
#include <stdio.h>
-#endif
#include <sys/types.h>
Index: ps/ps.map/local_proto.h
--- ps/ps.map/local_proto.h (revision 58395)
+++ ps/ps.map/local_proto.h (working copy)
@@ -42,9 +42,8 @@
/* do_labels.c */
int do_labels(int);
-#ifdef _STDIO_H
-#endif
/* do_masking.c */
int do_masking(void);
@@ -271,9 +270,8 @@
int accept(void);
int reject(void);
-#ifdef _STDIO_H
int print_session(FILE *);
-#endif
/* show_scale.c */
int show_scale(void);
@@ -299,9 +297,8 @@
int eps_bbox(char *, double *, double *, double *, double *);
int eps_trans(double, double, double, double, double, double, double, double,
-#ifdef _STDIO_H
int eps_save(FILE *, char *, char *);
int eps_draw_saved(char *, double, double, double, double);
int eps_draw(FILE *, char *, double, double, double, double);
int pat_save(FILE *, char *, char *);
-#endif
