[GRASS-dev] Removing _STDIO_H ifndefs
Vaclav Petras wenzeslaus at gmail.com
Tue Dec 10 09:33:55 PST 2013
Since there were no objections, I committed the patch in r58435. Patch
tested on Mac OS X Mavericks (clang)‎ and Ubuntu (gcc, clang).
[r58435] https://trac.osgeo.org/grass/changeset/58435
On Mac:
$ gcc --version
Configured with: --prefix=/Applications/Xcode.app/Contents/Developer/usr
--with-gxx-include-dir=/usr/include/c++/4.2.1
Apple LLVM version 5.0 (clang-500.2.79) (based on LLVM 3.3svn)
Target: x86_64-apple-darwin13.0.0
Thread model: posix
(note that gcc on new mac is clang not gcc)
On Ubuntu:
$ clang --version
Ubuntu clang version 3.0-6ubuntu3 (tags/RELEASE_30/final) (based on LLVM
3.0)
Target: i386-pc-linux-gnu
Thread model: posix
$ gcc --version
gcc (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3
Copyright (C) 2011 Free Software Foundation, Inc.
On Thu, Dec 5, 2013 at 10:57 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi all,
> there are some preprocessor ifndefs which I don't completely understand
> but, from what I understand, they should be removed.
> There are two contexts where it is used:
> #ifndef _STDIO_H
> #include <stdio.h>
> #endif
> which is useless since this check should be done in stdio.h.
> The other usage is:
> #ifdef _STDIO_H
> int do_label(FILE *, int);
> #endif
> which in case of not defined _STDIO_H will not declare that function and
> so it will break the code later in the compilation where this function is
> used (depending code is not marked by #ifdef).
> It actually breaks with standard C library which does not define _STDIO_H
> but something else, e.g. the one which goes with the latest Mac OS X XCode
> (at least to my current understanding). I guess there is not reason to to
> "ifdef stdio.h" any parts of code now, so we can just remove all these.
> Patch attached, once it is approved I will commit it. Compiled so far only
> on Ubuntu.
> Objections? Explanations?
> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131210/69dc750a/attachment.html>
