[GRASS-dev] segfault on 'r.stream.extract' - debian armh
epi massimodisasha at gmail.com
Fri Dec 6 10:06:46 PST 2013
i’m trying to run  “r.stream.extract” on a little linux machine, i got got grass up and running on a small quad-core Arm 1gb ram
OS :  Debian SID ArmHF.
the command i’m using is :
r.stream.extract elevation=elevation at PERMANENT accumulation=accum threshold=40 stream_rast=stream_network stream_vect=streams --o --q
i set the debug level to 5, this the segfault log :
https://gist.github.com/epifanio/7829206
if helpful, this is the log of make clean and make :
https://gist.github.com/epifanio/7829256
On other platform (same grass and r.stream.extract version it wks just fine)
Have you any idea on what’s wrong ?
Thanks,
Massimo.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131206/2d00161a/attachment.html>
