[GRASS-dev] segfault on 'r.stream.extract' - debian armh
Rashad M mohammedrashadkm at gmail.com
Fri Dec 6 13:16:09 PST 2013
Hello Massimo,
A gdb output could be more helpful for a segfault
On Fri, Dec 6, 2013 at 7:06 PM, epi <massimodisasha at gmail.com> wrote:
> Hi,
> i’m trying to run  “r.stream.extract” on a little linux machine, i got got
> grass up and running on a small quad-core Arm 1gb ram
> OS :  Debian SID ArmHF.
> the command i’m using is :
> r.stream.extract elevation=elevation at PERMANENT accumulation=accum
> threshold=40 stream_rast=stream_network stream_vect=streams --o --q
> location :  nc_spm_08_grass7/PERMANENT/
> i set the debug level to 5, this the segfault log :
> https://gist.github.com/epifanio/7829206
> if helpful, this is the log of make clean and make :
> https://gist.github.com/epifanio/7829256
> On other platform (same grass and r.stream.extract version it wks just
> fine)
> Have you any idea on what’s wrong ?
> Thanks,
> Massimo.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131206/e8cbf393/attachment.html>
