[GRASS-dev] segfault on 'r.stream.extract' - debian armh
epi
massimodisasha at gmail.com
Fri Dec 6 13:32:06 PST 2013
Hi !
this the output of gdb :
Starting program: /home/epi/Envs/env1/grass-7.0.svn/bin/r.stream.extract .stream.extract elevation=elevation50m at PERMANENT accumulation=accum threshold=40 stream_rast=stream_network stream_vect=streams --o
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Program received signal SIGILL, Illegal instruction.
0x2c966e68 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
(gdb)
Thanks for your help!
Massimo.
On Dec 6, 2013, at 4:16 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
> Hello Massimo,
> A gdb output could be more helpful for a segfault
> On Fri, Dec 6, 2013 at 7:06 PM, epi <massimodisasha at gmail.com> wrote:
> Hi,
> i’m trying to run “r.stream.extract” on a little linux machine, i got got grass up and running on a small quad-core Arm 1gb ram
> OS : Debian SID ArmHF.
> the command i’m using is :
> r.stream.extract elevation=elevation at PERMANENT accumulation=accum threshold=40 stream_rast=stream_network stream_vect=streams --o --q
> location : nc_spm_08_grass7/PERMANENT/
> i set the debug level to 5, this the segfault log :
> https://gist.github.com/epifanio/7829206
> if helpful, this is the log of make clean and make :
> https://gist.github.com/epifanio/7829256
> On other platform (same grass and r.stream.extract version it wks just fine)
> Have you any idea on what’s wrong ?
> Thanks,
> Massimo.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
> Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131206/ce67bdd7/attachment.html>
