[GRASS-dev] [GRASS GIS] #2145: wxGUI network analysis tool: fails to launch in French locale
GRASS GIS trac at osgeo.org
Fri Dec 20 05:49:23 PST 2013
  Reporter:  mlennert  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  7.0.0
 Component:  wxGUI     |     Version:  svn-trunk
Resolution:  fixed     |    Keywords:  network analysis tool
  Platform:  Linux     |         Cpu:  Unspecified
Changes (by mlennert):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:1 annakrat]:
 > This particular error should be fixed in r58490. There was an empty
 translatable string which resulted in some garbage.
 Thanks. I can confirm the fix. Closing this bug.
 > However, once certain strings get translated, you will get such errors
 again from multiple places. The code is pretty complex, converting to
 string is there multiple times and I am not sure how to fix this. In
 general, I don't really understand how to deal with this issue and how to
 test it correctly.
 I don't think there is one good way to fix this, but if we could propose a
 test protocol that allows developers to quickly test their work for
 different locale settings then maybe it would make it easier to avoid such
 issues in the first place.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2145#comment:2>
