[GRASS-dev] xganim: fix compilation or remove completely?
Glynn Clements
glynn at gclements.plus.com
Sun Dec 22 02:34:06 PST 2013
Vaclav Petras wrote:
> The only question is if wxpyimgview is as fast as wximgview. Speed
> is the only reason why they exists, isn't it?
Not really. A fundamental property of those programs is that they will
dynamically update the display whenever the image file changes.
For display commands which take a while to execute, updates can
continue during the drawing process.
This was a significant reason for supporting memory-mapped images:
once the file has been created, it remains valid even while being
modified.
