[GRASS-dev] [GRASS GIS] #719: v.edit tool=break: breaking more then 6 coords and producing of an unexpected line
trac at osgeo.org
Tue Dec 24 03:12:36 PST 2013
unexpected line
Reporter: achim | Owner: martinl
Type: defect | Status: assigned
Priority: major | Milestone: 6.5.0
Component: Vector | Version: svn-develbranch6
Keywords: v.edit tool=break | Platform: Unspecified
Cpu: Unspecified |
Comment(by GG1234):
I extracted the commands from the python script I use. Here it is :
def montest():
print g.run_command('v.patch', quiet=True, overwrite=True, input =
("Support_2","Raccos"), output="network")
file = open('Conn_Pt2.txt', 'r')
resultatParse = file.read()
file.close()
resultat = resultatParse.split("\n")
for macoord in resultat[1:]:
print "braking at point "+macoord
print g.run_command('v.edit', map = "network", layer=1,
tool = 'break', coords = macoord, thresh=1 ,overwrite=True)
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:12>
