[GRASS-dev] Is r.in.wms actually working? (Italian territory example)
Rashad M
mohammedrashadkm at gmail.com
Sat Feb 2 05:16:29 PST 2013
Are you behind a firewall or proxy?
Because r.in.wms in not hanging for me
r.in.wms mapserver=http://watzmann-geog.urz.uni-heidelberg.de/cached/osmlayers=osm_auto:all
output=osm format=png srs=900913
Downloading data from WMS server...
Reprojecting raster...
Importing raster map into GRASS...
ERROR: Sorry, <input> is not a valid parameter
ERROR: r.mask failed
ERROR: No existing MASK to remove
Exception SystemExit: 1 in <bound method WMSGdalDrv.__del__ of
<wms_gdal_drv.WMSGdalDrv instance at 0x1b60050>> ignored
Yes, Its not working yet but still downloading
On Sat, Feb 2, 2013 at 6:30 PM, Margherita Di Leo <dileomargherita at gmail.com
> wrote:
> Hi,
> I was trying to check if r.in.wms works on G7. I've tried to download from
> the pcn [1] but it seems not working, anyone has experienced this?
> BTW, I've tried also the examples from the manual page:
> r.in.wms url=http://irs.gis-lab.info layers=osm output=osm format=png
> ERROR: Unable to fetch capabilities from: 'http://irs.gis-lab.info'
> and
> r.in.wms url=http://watzmann-geog.urz.uni-heidelberg.de/cached/osmlayers=osm_auto:all output=osm format=png
> Takes forever, and when I try to kill it with Ctrl + C it doesn't respond..
> I would like to know if anyone of you has an example which is working for
> the Italian territory.
> Thank you,
> Madi
> [1] http://www.pcn.minambiente.it/PCNDYN/catalogowms.jsp
> Margherita DI LEO
> Postdoctoral Researcher
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES). Unit H03 – FRC
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at jrc.ec.europa.eu
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130202/3ddc89e8/attachment.html>
