[GRASS-dev] Is r.in.wms actually working? (Italian territory example)
Margherita Di Leo dileomargherita at gmail.com
Sat Feb 2 10:41:59 PST 2013
Thank you Rashad, it was simply slow, now managed to download with:
r.in.wms url=http://watzmann-geog.urz.uni-heidelberg.de/cached/osm
layers=osm_auto:all
output=osm format=png
The other OSM example on the manual page is yet not working for me, maybe
should be changed/removed?
cheers,
madi
On Sat, Feb 2, 2013 at 2:16 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
> Hi,
> Are you behind a firewall or proxy?
> Because r.in.wms in not hanging for me
>  r.in.wms mapserver=http://watzmann-geog.urz.uni-heidelberg.de/cached/osmlayers=osm_auto:all output=osm format=png srs=900913
> Downloading data from WMS server...
> Reprojecting raster...
> Importing raster map into GRASS...
> ERROR: Sorry, <input> is not a valid parameter
> ERROR: r.mask failed
> ERROR: No existing MASK to remove
> Exception SystemExit: 1 in <bound method WMSGdalDrv.__del__ of
> <wms_gdal_drv.WMSGdalDrv instance at 0x1b60050>> ignored
> Yes, Its not working yet but still downloading
> On Sat, Feb 2, 2013 at 6:30 PM, Margherita Di Leo <
> dileomargherita at gmail.com> wrote:
>> Hi,
>> I was trying to check if r.in.wms works on G7. I've tried to download
>> from the pcn [1] but it seems not working, anyone has experienced this?
>> BTW, I've tried also the examples from the manual page:
>> r.in.wms url=http://irs.gis-lab.info layers=osm output=osm format=png
>> ERROR: Unable to fetch capabilities from: 'http://irs.gis-lab.info'
>> and
>> r.in.wms url=http://watzmann-geog.urz.uni-heidelberg.de/cached/osmlayers=osm_auto:all output=osm format=png
>> Takes forever, and when I try to kill it with Ctrl + C it doesn't
>> respond..
>> I would like to know if anyone of you has an example which is working for
>> the Italian territory.
>> Thank you,
>> Madi
>> [1] http://www.pcn.minambiente.it/PCNDYN/catalogowms.jsp
>> Margherita DI LEO
>> Postdoctoral Researcher
>> European Commission - DG JRC
>> Institute for Environment and Sustainability (IES). Unit H03 – FRC
>> Via Fermi, 2749
>> I-21027 Ispra (VA) - Italy - TP 261
>> Tel. +39 0332 78 3600
>> margherita.di-leo at jrc.ec.europa.eu
>> Disclaimer: The views expressed are purely those of the writer and may
>> not in any circumstance be regarded as stating an official position of the
>> European Commission.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
>    Rashad
Margherita DI LEO
Via Fermi, 2749
Disclaimer: The views expressed are purely those of the writer and may not
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130202/39e8948e/attachment.html>
