[GRASS-dev] a minor but annoying bug just discovered with switching mapsets
Michael Barton Michael.Barton at asu.edu
Sun Feb 3 12:05:13 PST 2013
It doesn't matter how I use it.
If I ...
1. change from mapset A to mapset B using g.mapset
2. then quit GRASS (from within mapset B)
then when I restart GRASS, mapset B shows up as locked.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 3, 2013, at 12:57 PM, Anna Kratochvílová <kratochanna at gmail.com>
 wrote:
> On Sun, Feb 3, 2013 at 8:49 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> I'm emailing in case that anyone is still sprinting on the opposite side of
>> the world.
>> I just realized that if you change to a new mapset using g.mapset and then
>> quit (properly), the mapset you changed to with g.mapset appears as locked
>> the next time you try to open it. This is in trunk, but may affect other
>> versions.
> I am not sure what you mean. You use the g.mapset through menu (GRASS
> working environment->Change mapset)?
> Anna
>> Michael
>> C. Michael Barton
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
