[GRASS-dev] [GRASS GIS] #1736: wxNVIZ volume display crashes Mac
trac at osgeo.org
Mon Feb 4 09:51:34 PST 2013
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by cmbarton):
There are never any error messages because this is not a normal GRASS
module that goes through the GRASS error system. It simply crashes then
entire interface. The native error system says that the crash starts at
gvl_write_char. In the GRASS debug output, the second case crashes after
the "initialize OK" line.
If you compare the two debug outputs above, gvl_align_char allocates
enough memory for a resolution of 2 (1000000 > 349308) but runs twice and
allocates 2 chunks in the second case.
gvl_align_data correctly allocates the needed memory in both cases now.
I'm hoping that this is enough to suggest a fix.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1736#comment:24>
