[GRASS-dev] Ignored enhancements
Newcomb, Doug
doug_newcomb at fws.gov
Mon Feb 11 05:40:51 PST 2013
Seth,
I appreciate the effort. Working with large rasters, this will make a big
difference!
Doug
On Sun, Feb 10, 2013 at 9:18 PM, Seth Price <seth at pricepages.org> wrote:
> They should. I didn't really make any changes to the calculations, I just
> rearranged the code to make it more processor and compiler friendly.
> ~Seth
> via iPhone
> On Feb 9, 2013, at 3:27 PM, "Newcomb, Doug" <doug_newcomb at fws.gov> wrote:
> Seth,
> I finally got a chance to patch your enhancements from the GRASS 70 svn
> code I pulled last night.
> I compiled with these options:
> ./configure --with-gdal --with-freetype
> --with-freetype-includes=/usr/include/freetype2 --with-proj --with-sqlite
> --enable-largefile --with-cxx --enable-64bit --with-python --with-blas
> --with-lapack --with-cairo --with-wxwidgets --with-spatialite
> --with-tcltk --with-tcltk-includes=/usr/include/tcl8.4
> --with-liblas=/usr/local/bin/liblas-config --enable-largefile --with-openmp
> --with-readline
> The computer uses an AMD Vishera 8 core cpu with 8GB DDR3 1333 RAM (
> freshly updated home machine)
> I used this 23 million cell raster of 20ft bare earth elevation in the
> mountains of western North Carolina.
> Layer: nc_1 at PERMANENT Date: Thu Jul 5 20:56:51 2012
> | Mapset: PERMANENT Login of Creator: dnewcomb
> | Location: ncstpft
> | DataBase: /data1/grass7
> | Title: bilinear interpolation with Tykhonov regularization ( nc_1 )
> | Timestamp: none
> | Type of Map: raster Number of Categories: 7000
> | Data Type: DCELL
> | Rows: 5328
> | Columns: 4375
> | Total Cells: 23310000
> | Projection: Lambert Conformal Conic
> | N: 593000 S: 486439 Res: 20.00018769
> | E: 492500 W: 405000 Res: 20
> | Range of data: min = -8269.7102472716 max = 6999.76272107517
> | Data Description:
> | generated by v.surf.bspline
> | Comments:
> | v.surf.bspline -z input="nc_1 at PERMANENT" raster="nc_1" sie=40
> sin=40\ |
> | method="bilinear" lambda_i=0.01 layer="1" solver="cholesky"
> maxit=1\ |
> | 00 error=0.000001 memory=300
> First, with the default GRASS 7 svn pull from 2/9
> GRASS 7.0.svn (ncstpft):~ > time r.horizon -d elevin=nc_1 horizonstep=90
> horizon=test_normal
> Calculating map 1 of 4 (angle 0.00, raster map <test_normal_0>)
> 100%
> Calculating map 2 of 4 (angle 90.00, raster map <test_normal_1>)
> 100%
> Calculating map 3 of 4 (angle 180.00, raster map <test_normal_2>)
> 100%
> Calculating map 4 of 4 (angle 270.00, raster map <test_normal_3>)
> 100%
> real 16m14.028s
> user 16m11.993s
> sys 0m1.860s
> Second, patching r.horizon main.c with the diff file from your patch.
> horizon=test_price
> Calculating map 1 of 4 (angle 0.00, raster map <test_price_0>)
> 100%
> Calculating map 2 of 4 (angle 90.00, raster map <test_price_1>)
> 100%
> Calculating map 3 of 4 (angle 180.00, raster map <test_price_2>)
> 100%
> Calculating map 4 of 4 (angle 270.00, raster map <test_price_3>)
> 100%
> real 14m22.607s
> user 14m20.582s
> sys 0m1.836s
> Using r.mapcal to subtract the normal r.horizon calculation from the
> modified calculation shows 0 difference between the two results
> I usually run r.horizon on a 755 million cell grid and do 24 horizons, I
> am assuming the the benefits would scale proportionally?
> Doug
> On Mon, Feb 4, 2013 at 12:40 PM, Seth Price <seth at pricepages.org> wrote:
>> A while ago I made some simple, but significant, enhancements and
>> submitted them to trac. They haven't been picked up, so I wanted to point
>> them out so someone can commit them before they diverge from the trunk.
>> http://trac.osgeo.org/grass/ticket/1624
>> This has had some activity recently, but it's status is still "new" and
>> it isn't in trunk.
>> http://trac.osgeo.org/grass/ticket/1575
>> ~Seth
>> via iPhone
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Doug Newcomb
> USFWS
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> The opinions I express are my own and are not representative of the
> official policy of the U.S.Fish and Wildlife Service or Dept. of the
> Interior. Life is too short for undocumented, proprietary data formats.
Doug Newcomb
USFWS
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130211/fe757257/attachment-0001.html>
