[GRASS-dev] Ignored enhancements
Seth Price
seth at pricepages.org
Sun Feb 10 18:18:52 PST 2013
They should. I didn't really make any changes to the calculations, I just rearranged the code to make it more processor and compiler friendly.
~Seth
via iPhone
On Feb 9, 2013, at 3:27 PM, "Newcomb, Doug" <doug_newcomb at fws.gov> wrote:
> Seth,
> I finally got a chance to patch your enhancements from the GRASS 70 svn code I pulled last night.
> I compiled with these options:
> ./configure --with-gdal --with-freetype --with-freetype-includes=/usr/include/freetype2 --with-proj --with-sqlite --enable-largefile --with-cxx --enable-64bit --with-python --with-blas --with-lapack --with-cairo --with-wxwidgets --with-spatialite --with-tcltk --with-tcltk-includes=/usr/include/tcl8.4 --with-liblas=/usr/local/bin/liblas-config --enable-largefile --with-openmp --with-readline
> The computer uses an AMD Vishera 8 core cpu with 8GB DDR3 1333 RAM ( freshly updated home machine)
> I used this 23 million cell raster of 20ft bare earth elevation in the mountains of western North Carolina.
> Layer: nc_1 at PERMANENT Date: Thu Jul 5 20:56:51 2012 |
> | Mapset: PERMANENT Login of Creator: dnewcomb |
> | Location: ncstpft |
> | DataBase: /data1/grass7 |
> | Title: bilinear interpolation with Tykhonov regularization ( nc_1 ) |
> | Timestamp: none |
> | Type of Map: raster Number of Categories: 7000 |
> | Data Type: DCELL |
> | Rows: 5328 |
> | Columns: 4375 |
> | Total Cells: 23310000 |
> | Projection: Lambert Conformal Conic |
> | N: 593000 S: 486439 Res: 20.00018769 |
> | E: 492500 W: 405000 Res: 20 |
> | Range of data: min = -8269.7102472716 max = 6999.76272107517 |
> | Data Description: |
> | generated by v.surf.bspline |
> | Comments: |
> | v.surf.bspline -z input="nc_1 at PERMANENT" raster="nc_1" sie=40 sin=40\ |
> | method="bilinear" lambda_i=0.01 layer="1" solver="cholesky" maxit=1\ |
> | 00 error=0.000001 memory=300 |
> First, with the default GRASS 7 svn pull from 2/9
> GRASS 7.0.svn (ncstpft):~ > time r.horizon -d elevin=nc_1 horizonstep=90 horizon=test_normal
> Calculating map 1 of 4 (angle 0.00, raster map <test_normal_0>)
> 100%
> Calculating map 2 of 4 (angle 90.00, raster map <test_normal_1>)
> 100%
> Calculating map 3 of 4 (angle 180.00, raster map <test_normal_2>)
> 100%
> Calculating map 4 of 4 (angle 270.00, raster map <test_normal_3>)
> 100%
> real 16m14.028s
> user 16m11.993s
> sys 0m1.860s
> Second, patching r.horizon main.c with the diff file from your patch.
> GRASS 7.0.svn (ncstpft):~ > time r.horizon -d elevin=nc_1 horizonstep=90 horizon=test_price
> Calculating map 1 of 4 (angle 0.00, raster map <test_price_0>)
> 100%
> Calculating map 2 of 4 (angle 90.00, raster map <test_price_1>)
> 100%
> Calculating map 3 of 4 (angle 180.00, raster map <test_price_2>)
> 100%
> Calculating map 4 of 4 (angle 270.00, raster map <test_price_3>)
> 100%
> real 14m22.607s
> user 14m20.582s
> sys 0m1.836s
> Using r.mapcal to subtract the normal r.horizon calculation from the modified calculation shows 0 difference between the two results
> I usually run r.horizon on a 755 million cell grid and do 24 horizons, I am assuming the the benefits would scale proportionally?
> Doug
> On Mon, Feb 4, 2013 at 12:40 PM, Seth Price <seth at pricepages.org> wrote:
>> A while ago I made some simple, but significant, enhancements and submitted them to trac. They haven't been picked up, so I wanted to point them out so someone can commit them before they diverge from the trunk.
>> http://trac.osgeo.org/grass/ticket/1624
>> This has had some activity recently, but it's status is still "new" and it isn't in trunk.
>> http://trac.osgeo.org/grass/ticket/1575
>> ~Seth
>> via iPhone
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Doug Newcomb
> USFWS
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130210/8f70fde0/attachment.html>
