[GRASS-dev] does GRASS 7 for Mac compile yet?
William Kyngesburye woklist at kyngchaos.com
Tue Feb 5 06:42:35 PST 2013
>> On the wxpython-problematic for OS-X:
>> - python 2.7
>> <http://python.org/ftp/python/2.7.3/python-2.7.3-macosx10.6.dmg>
Python 2.7 is in the Mac system starting with 10.7 (Lion).  And on 10.6, the system python 2.6 works just fine.
>> - wxpython 2.9 (the cocoa build)
>> <http://downloads.sourceforge.net/wxpython/wxPython2.9-osx-2.9.4.0-cocoa-py2.7.dmg>
More correctly - install wxpython 2.9 to match your python.  For OS X 10.6 users, you would install wxpython 2.9 carbon py2.6.
> and
> - numpy
> <http://garr.dl.sourceforge.net/project/numpy/NumPy/1.6.1/numpy-1.6.1-py2.7-python.org-macosx10.6.dmg>
Well, if you are using my GDAL framework for GRASS, it has a numpy installer in the download (and it's also available as a separate download).  This is made for the system python (the official binaries are made only for the python.org python).
>> and then set up properly GRASS to pick those up?
> O-kay, it seems it works :-)
> Configured by setting
> "--with-wxwidgets=/usr/local/lib/wxPython-2.9.4.0/bin/wx-config",
> compiled, and "correcting" another locale-related problem (setting
> LC_CTYPE=en_US.UTF-8) .
> We can now proceed in debugging errors... :-)
> Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
