[GRASS-dev] does GRASS 7 for Mac compile yet?
Michael Barton Michael.Barton at asu.edu
Tue Feb 5 09:15:54 PST 2013
I recommend NOT installing a 3rd party Python.
OS X 10.7 and 10.8 already come with Python 2.6 and 2.7 installed. My installation instructions, worked out with William Kyngesburye are designed so that GRASS will work with Python 2.6 and OS X 10.6 (which many people still use).
I get a series of "errors" during compiling that say 'can't find wx'. But these are bogus. All the affected modules (e.g., mapswipe) work fine.
If you cannot launch the GUI there is some kind of different problem.
1) What OS are you using? If you have OS X 10.6, you need to follow different instructions from what I said. Also, you need the 10.6 SDK's in order to compile a version that works on 10.6 if you are running 10.8.
2) Often a failure to launch is actually traceable to an out of date GDAL version, though this should not be a problem if you are compiling yourself.
3) Another reason for a launch failure is a mismatch between the location of wxPython in the configure script and where it really is located on your computer.
You might try to download my GRASS 7 binary, compiled Sunday night, and see if it runs with all the proper frameworks installed (these are also on the site).
You can find it at <http://www.public.asu.edu/~cmbarton/files/grass_mac/OSX10.6-snowleopard/>
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
On Feb 5, 2013, at 5:24 AM, Nikos Alexandris <nik at nikosalexandris.net>
 wrote:
> On the wxpython-problematic for OS-X:
> I can compile grass_trunk which ends up with various wxpython related
> errors.  So, the gui wont launch.  Could it be that we only need to
> properly install
> - python 2.7 <http://python.org/ftp/python/2.7.3/python-2.7.3-macosx10.6.dmg>
> - wxpython 2.9 (the cocoa build)
> <http://downloads.sourceforge.net/wxpython/wxPython2.9-osx-2.9.4.0-cocoa-py2.7.dmg>
> and then set up properly GRASS to pick those up?
> Since I have no previous experience under OS-X (only linux here), I can't
> easily switch python versions, etc.
> Thanx, Nikos
