Luca wrote: > Instead manually, could you change in a daily cronjob? keep in mind that the shared VM that it is run on is generally under considerable load (but not at capacity), and anything extra on top won't help that situation. Maybe we could put a nightly build on the adhoc VM and keep the existing one once a week? best, Hamish
