[GRASS-dev] reg i.pca module
Markus Metz markus.metz.giswork at gmail.com
Fri Feb 8 15:45:18 PST 2013
On Fri, Feb 8, 2013 at 4:48 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
> Hi,
> On Thu, Feb 7, 2013 at 2:46 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> On 07/02/13 06:31, Rashad M wrote:
>>> Hi
>>> As mentioned in wiki does the output pixel = eigenvector * input pixel?
>> Yes, possibly depending on how the eigenvector is formulated. PCA is
>> "just" a linear transformation from original pixel space to PC space.
> What do you mean by depending on "how the eigenvector is formulated"?
>From the example in the manual:
The first PCA has the eigenvector
0.2824, 0.3342, 0.5092,-0.0087, 0.5264, 0.5217
Thus the output cells for PCA1 are calculated with
PCA1 = 0.2824 * (band1 - mean(band1) + 0.3342 * (band2 - mean(band2) +
... + 0.5217 * (band7 - mean(band7))
The output cells for the other PCA's are calculated accordingly.
> Can anyone confirm this because its blocking me
HTH,
Markus M
