[GRASS-dev] g.gui fails
Pierre Roudier pierre.roudier at gmail.com
Sun Feb 10 14:03:32 PST 2013
Hi Anna,
Weird - I can launch parallel g.gui instances without any problem in
(X)Ubuntu 12.04.1, with grass70 compiled against the latest trunk.
Cheers,
Pierre
2013/2/11 Anna Kratochvílová <kratochanna at gmail.com>:
> Hi,
> I've upgraded today from ubuntu 10.04 to 12.04 and now I have problems
> to start wxGUI. Launching grass is OK, the GUI appears but when I want
> to open a new one with g.gui, it refuses to open because it is not
> able to import wxversion and wx (in globalvar.py). When I launch
> python in command line, I can import both wxversion and wx without
> problems. Launching gui directly - python gui/wxpython/wxgui.py& -
> works (using python 2.7). Is there something special about the g.gui
> command? Any ideas where could be the problem?
> Thanks,
> Anna
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Scientist
Landcare Research, New Zealand
