[GRASS-dev] [GRASS GIS] #1880: change color field to text for d.vect.chart
trac at osgeo.org
Sun Feb 10 08:27:45 PST 2013
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Display | Version: 6.4.2 RCs
Keywords: d.vect.chart, color arguments | Platform: All
Cpu: All |
The color argument for d.vect.chart is defined in such a way that the GUI
converts it to a color chooser (interactive way to select colors) for the
properties dialog in the layer manager.
The problem is that this field needs to accept MULTIPLE colors, not a
single color. This is where the colors for different data fields are
chosen so that they appear as different colors in the charts. A single
color chooser makes this useless.
So unless there is a way for a color chooser to create a list of colors,
this argument needs to be redefined as text that accepts a list of comma-
separated colors.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1880>
